Rebar Cage Guying/Bracing
Does anyone know how to check the strength of a rebar cage when it is braced or guyed? I am not counting on the horizintal bars for strength (no horizontal shear flow), so I am summing the bar properties about a guy location. I am applying the wind load specified by the CalTrans Spec for rebar cages, but they do not provide any guidance on how to analyze the cage.
RE: Rebar Cage Guying/Bracing
Cages which are shop fabricated and welded may be stiffer and stronger, but the forces on the welds can be excessive when the cage acts as a truss.
Cages may be subject to large wind loads. Un-guyed cages can displace laterally far enough that gravity will force them down
That is my long-winded way of saying that bracing/guying must be based on the flexibility of individual longitudinal bars.
US OSHA says:
1926.703(d)
Reinforcing steel.
1926.703(d)(1)
Reinforcing steel for walls, piers, columns, and similar vertical structures shall be adequately supported to prevent overturning and to prevent collapse.
John Turner CSP PE
CRSI Greater Southwestern Regional Manager
Thank you.
I am familiar with the OSHA guidelines. They are very vague and give no help from a structural stand point. Believe me, I want to keep the steel vertical. Does CRSI have a committee on the guying of rebar cages? I would be interested in learning more.
Due to the complexity of analyzing the cage my preferred method is to set up half the form, fly in the cage and then set the second half of the form. This takes the strength of the cage out of the problem and is adequate for most small columns. I am finding some projects where the workers like this approach, and other projects they don't. I also prefer to keep workers off the cage. Stay off the thing and use a manlift if needed!
