concrete mix design for piles and or cassons
Sorry, I forgot to tell you the specs for these cassons is 25 mpa. I would like to use a 20mpa footing mix with 40 to 50% slag . Iam I asking for trouble? Thanks
RE: concrete mix design for piles and or cassons
Use a 25mpa mix with slag cement if you want, with the understanding that your strength gain will be slower and might not achieve the ultimate in the time frame (28 days, typically).
Dik
