Non-planar 2d curves
How to attach reference plane to 2d curves exported from drafting via Export to Solids?
In many cases it's not possible to constrain it because it doesn't lie on a work plane, any suggestions?
RE: Non-planar 2d curves
Create an empty part
Create your plane
Move or align your curves to that plane
You may have to move them away from the plane then back again
Then "attach" the curves to the part
Then you should be able to sketch on that plane and constrain and dimension the curves.
