Fitting drawing or model needed
I need to use a MS21921-10J swivel nut/fitting in an assembly.  I have not found a drawing or model for it to get the details from.  Anyone know where I can find one?
Ed
RE: Fitting drawing or model needed
Parker Hanifin have a series of interactive programs called Inphorm. One of them contains a very wide range of fluid power connectors.
When the fitting type and size has been confirmed, there is an option at the end to create a 2d dxf or dwg file.
There are also plenty of fittings available at 3dcontentcentral.com
