Hole File - Default Depths
Hello All,
I am creating a custom .hol file in WF4. When I create a hole the default depths are calculated by ProE(ie. drill depth=3*drill diameter). Is there a way that I can change either the calculation or set it up in the hole file to have the depths that I want??
Any help would be greatly appreciated.
RE: Hole File - Default Depths
Look picture
regards
Wildfire is very nice, if you know,
how work with him
