Warning Corrosion Risk
Does anyone have a *.dwg file for a "Warning Corrosion Risk" sign that they can share?
thanks, Dik
RE: Warning Corrosion Risk
If there isn't one available, I'll do one up using plines.  It's for a chainlink fence around an HCl containment area.
Dik
http://praevention.portal.bgn.de/558
Download the W04.wmf -> insert the sign with "wmfin" into you Acad ->make a solid hatch -> ready
Lothar
ADT 2004
Thanks... Dik
