Wing Structure Problem
Hi all,
Iam trying to use the multisectionsolid function to create my wing but when i try to use it i never sucess. i tried with the arrows but no action. Please se attaced file and help me.
Best Regards
RE: Wing Structure Problem
You need to pick the Closing Points so that they match (I think that's the problem).
-Mark
Hi Mark, i tried that does not work ?
Start with MarkAF's suggestion and use matching closing point, the sharp edge on the back of the wing should be good, then go to the coupling tab and use vertices and match corresponding vertices on the sketches ie the connecting point of the guides, by the way don't think you need any guides due to there is only two sections and the guides are straight lines.
thank u Mark and Azrael. U solved it :)
