Sweeping along a curve
I am trying to sweep along a curve but ProE does not like my curve. How can I fix this?
RE: Sweeping along a curve
If the curve is 3d you should use the Swept Blend option which was improved or WildFirized in WF3 or WF4. This works well for equation driven helix curves or Curve by 2 Projections Intersection
If you are doing a regular 2d sketch for your sweep you want to make sure that your section curve Cross Section doesn't violate the minimum radios of the sweep path.
Michael
