Problem Renaming iParts
I have some funky behavior using Inventor 11 (not my choice to not upgrade...) and renaming of iParts and iAssemblies.
Let us say I have an iPart called "TEST_PART.ipt" and it has children with member-names "TEST_PART-1.ipt" and "TEST_PART-2.ipt".
Now I have all of this checked into vault.
I rename (using Vault) the factory "TEST_PART.ipt" to something else. "1234.ipt".
Problem: The children do not rename. I would expect the membername and partnumber of the children to become "1234-1.ipt and 1234-2.ipt". They do not. They are still "TEST_PART-1 and 2".
When I check out the factory for edit, it will warn me that the part number no longer jives, however it will only fix the currently selected member (a problem if I have 50+ members in a factory!). I need to manually edit the table to correct all of the part numbers. And I CANNOT manually correct the MEMBER NAMES, since that will break all links with parent assemblies! I thought the point of Vault was to handle this renaming and re-establishing of the links?
Is this an artifact of my ancient version 11 or am I misunderstanding how this is supposed to work?
RE: Problem Renaming iParts
I specifically asked our cad-resellers this question and I got a sort of "oh, of course it works well with iParts" response.
I don't see a way around using iParts, but they cause me all kinds of grief in trying to make them behave.
