SEAL CHAMBER PRESSURE
High energy barrel pump.
If you start one of these (or any multi-stage, between-bearings pump)with the discharge valve nearly shut...will the pressure developed by the impellers be transferred to the seal chambers, ie. apprach discharge pressure ? (...while the thrust bearing takes a beating)
RE: SEAL CHAMBER PRESSURE
Johnny Pellin
Johnny Pellin
