SW opening file error
When I try to open a part or assembly file I get this message: "An error has occurred and SolidWorks need to re-start"
If I try to open a drawing file it start OK, with that .SLDDRW open I can open or create any part or assembly file.
I have un-installed and re-installed SW, still the same.
SW 2010 have been used on same PC for months with no problem.
I am using Vista Business, memory 2048MB. Graphics: 256nVIDA Quatro FX570.
Any idea?
So fare I will start work by first opening a drawing.
/Bjorn
RE: SW opening file error
documenteria,
   Are all your assemblies failing, or just one?
               JHG
This may have something to do with the fact that 2010 is a resource hog.  Might I suggest upgrading your memory to at least 12GB (assuming you are using 64-bit OS).
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
