46 Negative sequence relay
I'm looking for the cut sheet or instruction manual for the
westinghouse 46 style 1876175 negative sequence relay.
RE: 46 Negative sequence relay
Have you tried ABB?
Look up www.electricalmanuals.net then look under protective  relays, then ABB then COQ relays and see if you find anything worthwhile.
