Parameterize a scaled model?
Hi guys, I'm relatively new to UG, I was wondering if someone could talk me through how to take a model which is scaled up from another model, fully parametrize that scaled model, and then create me own copy (manually) of it
RE: Parameterize a scaled model?
Fully parametize? probably not, but it depends on the model, some things can be parametized, and some not.
A copy: either STEP or parasolid works fine.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
That functions works I for bodies but not curves. And whether the model is parametric or not. So a typical workflow might be to wave link the body from you parametererised original model and then just add scale to it.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Good answer, though!
