Can I hide Detail View circles?
4
I had to use 2 detail views to get what I wanted.  How can I hide 1 of the circles?
RE: Can I hide Detail View circles?
As I understand your problem, you created a detail of a detail.  Perhaps you can crop the first detail view instead.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Certified SolidWorks Advanced Weldment Specialist
You want to hide one of the circles used to create a detail, or the circle around the detail view itself?
I want to hide one of the circles used to create the detail, not the circle around the detail view.
Ditto to Shaggy.  It sounds like the actual area you wanted to show would lead to a tiny detail callout.  You can instead create a larger detail view with the proper magnification and then crop it down to size.
