Staad Shear/Moment Diagrams on physical member
Is there any easy way to see shear/moment diagrams for complete beams (ie, not just from node to node, but from support to support)? I understand that you can see the shear/moment diagrams for a specific beam number, but after creating physical members in the steel design module, i would like to see the shear/moment diagram of the full beam.
RE: Staad Shear/Moment Diagrams on physical member
If you click on the icon of the "Select Physical member cursor" and you then (double)click on the physical member that you are interested in, you can finally see the diagrams that you want for the whole member.
