15B30 steel
15B30 steel
15B30 steel
I am looking for source of the above boron treated steel in
1/4 X 2 and 1/4 X 2 1/2 bar. Current requirement is 200 T
annually. I have looked and looked and have struck out.
Thanks in advance for any help.
RE: 15B30 steel
If you are looking for cold drawn rectangular/shaped bar, then I suggest you contact companies that specialize in this such as Precision Kidd, Bekaert (formerly Contours), Rathbone, etc. in addition to the usual suppliers of cold drawn bars like Nucor, Niagara-LaSalle, St. Louis Cold Drawn, etc.  Here are some links you can use for more information:
Precision Kidd
http://www.precisionkidd.com/special_shapes.htm
Bekaert Shaped Wire
http://www.bekaertshapedwire.com/
Rathbone Profiles
http://www.rathboneprofiles.com/
