Cone flattening problem, what's the diff between these files?
Howdy all,
After my post yesterday I printed to scale the flat pattern and compared it to the template our welders have been using and I found a weird problem.  I have included 4 files to explain the problem.  CONETEST.SLDPRT is a cone and CONETEST.SLDDRW is its drawing as a flat pattern to scale.  FW0037-04-01.SLDPRT is what I thought to be an identical cone with drawing FW0037-04-01.SLDDRW.
I actually printed FW0037-04-01.SLDDRW for the comparison and it didn't quite fit and I noticed that one side was almost a 1/4 inch shorter then the other.  There was a 10" X 10" scale box to check the scale of my drawing and the box is 9.98" X 9.98".  Not perfrect but the drawing scale could not be the error.  As a matter of fact I sketched a line in the drawing right next to the flat pattern edge and the edge reads 16.47" and the line I sketched indicates 16.25".
When I saw this I created the print again using CONETEST and all the dimensions come out correctly here.  I'm stymied and I can't tell what the difference is between these two files.  Thanks for reviewing this for me.
Here are the files:
http://files.engineering.com/getfile.aspx?folder=ebad4fc0-25a4-4b14-869b-51c13bd1611a&file=CONETEST.SLDPRT
http://files.engineering.com/getfile.aspx?folder=f688034c-fd03-4e0b-9589-d2a00aa99dfd&file=CONETEST.SLDDRW
http://files.engineering.com/getfile.aspx?folder=cec56dfe-5e49-448b-99ea-abc4ebf107e7&file=FW0037-04-01.SLDPRT
http://files.engineering.com/getfile.aspx?folder=d8876c2c-3026-49e2-a01f-5d0f75f0b93a&file=FW0037-04-01.SLDDRW
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Cone flattening problem, what's the diff between these files?
in your drawing FW0037-04-01.SLDDRW the view is not in right projection.
