TopSolid - compatibility
Hi, it's the first time I write on this forum, but I red many topics.
You are all very competent, compliments! :)
My actual problem is that an external designer is sending us many important projects in d3d.
He works with an old version of TopSolid that is not compatible with our one...
We use also Proe and autocad 2000.
I need suggestions to manage this situation, because we can read the files but we cannot modify them.
thanks!
thanks!
RE: TopSolid - compatibility
Mike Halloran
Pembroke Pines, FL, USA
Are you really asking if there is a CAD neutral format both systems can open & modify?
I have been in situations where customers explicitly state what CAD package (even down to version) they want used. As a vendor you either get that CAD system (or subcontract your self to someone that has it), or you no longer bid the work.
Some CAD companies have schemes for companies to loan their licenses to vendors - or at least get discounts on them etc.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
TTFN
What are you reading them with, and can it "save as" or export them to other formats?
