another v8i problem
another v8i problem
several of my coworkers and I have had the following problem: we will inadvertantly drag (i assume this is how it happens) the inroads box off of the screen and not be able to retrieve it. in past versions, we could change the resolution to the lowest setting and then change it back to bring the box back onto the screen...this no longer works. we are now going as far as reinstalling microstation and inroads to fix the problem. Is there an easier fix?
RE: another v8i problem
The position of the dialogs are stored in HKEY_CURRENT_USER\Software\Bentley\InRoadsGroup\Applications\Version 8.XX\DialogPos
Be careful editing registry!
Do you sometime use dual monitors. Perhaps activating the second monitor and making it the primary monitor will shift the dialog back.
HTH,
Bob Mecham
www.envisioncad.com
