radial displacment in Patran with tet elements
I have been trying to figure out how to apply a radial displacement on a tube surface that is done with tet elements.  I have an interference fit from the tube to a plate and I will split the difference and apply to both the tube and plate to determine the stresses.
Ideas or examples?  Thank you in advance.
RE: radial displacment in Patran with tet elements
Use a cylindrical coordinate system aligned along the tube, and use that system to enforce displacement
