Submerged pH probe in Chemical tank?
Hi, I need to have a pH/temp probe in a chemical mixing tank. This tank will only be used about once every three months and the rest of the time will be empty. It will also be used to neutralize chemical. I am having trouble figuring how to make the pH probe wet at all times. Even if we left a little bit of water in the tank, it would evaporate after a couple of months. I think the easiest method we've thought of is to just have the operator remove the probe and put it in solution every time the tanks are not in use. Any ideas better than that?
RE: Submerged pH probe in Chemical tank?
"Being GREEN isn't easy" ..Kermit
http://www.youtube.com/watch?v=hpiIWMWWVco
http://virtualpipeline.spaces.live.com/
