Filling in autoshapes
I'm trying to fill in a Autoshape in excel based on the result of a calculation.
i.e. if cell B1>0 then fill in autoshape 136 with red.
I am using this code:
Private Sub Worksheet_Calculate()
Dim ThisWS As Worksheet
Set ThisWS = Me
If ThisWS.Range("b1") > 0 Then
ThisWS.Shapes(136).Fill.ForeColor.SchemeColor = 10 ' Red
Else
ThisWS.Shapes(136).Fill.ForeColor.SchemeColor = 0
End If
End Sub
When I do this excel returns the message
"run time error (then a bunch of numbers)
The index into the specified collection is out of bounds"
The autoshape is a donut
It seems to work if the autoshape number is lower like 50.
If there is a better way to do this I would appreciate the help.
Set ThisWS = Me
Else
End If
End Sub
RE: Filling in autoshapes
Row = 1 'Row=1
Column = 2 'Column=B
If Cells(Row, Column) > 0 Then
ActiveSheet.Shapes("Donut 1").Select
Selection.ShapeRange.Fill.ForeColor.SchemeColor = 10
Else
Selection.ShapeRange.Fill.ForeColor.SchemeColor = 0
End If
End Sub
