Can I replace MSRL pipes with SS304 pipes
We are facing problem with MSRL (Mild Steel Rubber Lined)pipes in Caustic Service. The internal rubber lining is peeling off and choking the piping causing process problem.
Pipe sizes are 3", 4" & 6" and are being used for Caustic service ( 5% and 50 DegC) & H2SO4 Conc. 5 to 10% at ambient temperature.
As no rubber Lined repair service provider is available locally. We are looking forward for a long term solution.
We plan to replace the affected MSRL piping with SS304 piping.
Any limitations from corrosion angle in thsi replacment?
RE: Can I replace MSRL pipes with SS304 pipes
Cheers,
gr2vessels
Ofcourse we are using sulphuric acid and caustic in different pipes in DM plant.
thanks for input on suphuric acid.
I see the FAQ and it is well explaning...
Eng tips forum is a great virtual space with a galaxy of expereinced and itellectuals. ...!
Wishing all the best for this awesome forum...!
