Passive Voice
Passive Voice
A)
On April 19th, 2010, a site inspection was performed at Project Site X by My Company Inc. Many deficiencies were identified.
B)
On April 19th, 2010, My Company Inc. performed a site inspection at Project Site X. MCI identified many deficiencies.
I was always taught B in High School and Undergrad, then got out into the work force and was told by my superiors to scrap B and go with A. Then a couple of years later, I went back to get my Masters degree, took an engineering specific grad level technical communication class, and asked the question specifically. They said, "B, don't ever use A, your old bosses were wrong." I graduate, go to work for another firm, and work seven years for them during which time they prohibit me from doing 'B' in reports and instead require 'A.'
Well now I've recently embarked on the adventure of owning my own consulting company, so I can write reports any way I darn well please, so I'm considering switching back to 'B.'
Thoughts?
B)
Thoughts?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
RE: Passive Voice
i think your bosses had their opinion, and now you're your own boss, you can have your own !
RE: Passive Voice
It is nothing but a stylistic difference. Religious/cultural, almost.
As rb1957 says, here's your chance to move the trend in whatever direction you think appropriate.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
RE: Passive Voice
"On April 19th, 2010, My Company Inc. identified many deficiencies during a site inspection at Project Site X."
RE: Passive Voice
Clearly I'd go with something like that. I just wrote those up to make sure we all were on the same page regarding the active/passive voicing question.
Thanks for the input.
RE: Passive Voice
==> On April 19th, 2010, a site inspection was performed at Project Site X by My Company Inc.
The subject is the site inspection.
==> On April 19th, 2010, My Company Inc. performed a site inspection at Project Site X. MCI identified many deficiencies.
The subject is My Company, Inc.
I would choose the voice which best represents who/what I want to be the subject: My Company or the site inspection.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: Passive Voice
Rafiq Bulsara
http://www.srengineersct.com
RE: Passive Voice
Stuff that I've written for publication (with an editor) always comes back more active than I wrote it. It also comes back easier to read and follow.
A much as I hate editors (they always like the taste of something better after they've peed on it), I hate it even more when they're right and their changes improve my work.
Do it however it will feel best for you to read in a month.
David
RE: Passive Voice
The biggest problem, I think, is that to maintain consistent grammar you must continue to use passive voice once your have started. That will lead to excessive wordiness and a very boring read. You are the boss now. You call it.
Alternative: The decision to use passive voice can be made by the person who is the boss.
RE: Passive Voice
I tend to copy this across to other technical writing I do.
I had a nice big debate with JSeagull about this a while back.
I seem to recall writing my science reports in more of a passive voice at school, and being hounded to do so.
I find active to come across as informal - even amateurish or sloppy.
However, when I get involved in actual detailed assembly instructions or the like, then I go active.
Then again, I don't recall it ever being called active or passive, so why believe me.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Passive Voice
Passive voice tends to emphasise the verb itself and the "receiver" of the verb, whereas active voice tends to emphasise the "doer"; for example:
Active voice: "MCI found many defects" tends to emphasise the fact that it was MCI that found the defects; it may imply a corollary that another inspector may NOT have found the defects. This would be a particularly appropriate construct where the identity of the "agent" is significant.
Passive voice: "Many defects were found" tends to emphasise the fact that defects were found, and in my view reduces the implication that the identity of the inspector was material in whether defects were identified.
There is a common view that active voice is "snappier" and clearer than passive voice. I don't think this is necessarily true. For example:
Passive voice: "Never in the field of human conflict was so much owed by so many to so few."
Active voice: I won't even attempt to better that!
The main thing for me is that you stick with one or the other when writing a piece; avoid mixing active and passive; e.g.
"The site was inspected by MCI on Friday 13th. MCI found many defects."
This is often the reason that organisations mandate passive (or active) voice in all reports - to ensure that all reports which are written "by committee" have a consistency of style and clarity. (Consistency of tense - past tense vs. present tense - is even more important in my view.)
RE: Passive Voice
Maybe the example is trivial, but if you extend that into lengthy reports, you'll find that you'll lose the reader where the report is too long versus a more concise report.
So I favor a more active approach and one that is more to the point.
RE: Passive Voice
RE: Passive Voice
RE: Passive Voice
- Steve
RE: Passive Voice
That'd be this:
Never in the field of human conflict had so many owed so few so much.
Right?
You take the noun after the 'by' and make it the subject, and the noun after the 'to' and make it the object. Or is the "Never in the blah blah blah" confusing the issue?
RE: Passive Voice
RE: Passive Voice
Hg
RE: Passive Voice
Passive is common here as well. In the last revision to our standard specifications we changed from passive voice (in place for the better part of a century) to active voice and a lot of people didn't like it.
I think as an undergrad I was taught to use passive in technical reports.
I like active voice, imperative mood for specifications. "Do this, do that." These days I don't feel very strongly about which way to go in reports. I like the idea of fewer words, but on the other hand if every single sentence starts with "we" or the company name, that gets irritating too.
Hg
RE: Passive Voice
This is where 'active' falls down for me, you implicitly tell them how to do something most of the time. Often there is more than one way to skin a cat, I want which ever one gives me best value - normally I don't care which.
For example - it's common for areas on a part to be free of paint or whatever surface finish is applied. My preference is just to identify the area and state 'SHALL BE FREE OF finish". This is the end result you want and what you can inspect.
Many other folk like to say things like "MASK IDENTIFIED SURFACES BEFORE FINISHING". How do you verify that they indeed masked those areas, rather than maybe machining after finishing? Do you really care? For some situations I've had vendors that wanted to machine certain features after finishing because it was easier than masking.
I tend to extrapolate this to written requirements and the like - specify the end result you want - not how you think it might be achieved.
Obviously there are some occasional gray/grey areas but the above argument, combined with it being how I was taught, convinces me
RE: Passive Voice
Active voice is briefer than passive voice.
A point Richard Mitchell makes is that passive voice eliminates the actor from the description.
This can be significant. Passive voice is harmless if you use it carefully, but you might want to read carefully.
RE: Passive Voice
RE: Passive Voice
The rule we typically follow is that if it is a "letter" report of a few pages and a signature at the end, we use an active voice approach. If it is a formal report (cover letter, table of contents, etc.) is is usually written in 3rd person and the passive voice will prevail, though there's usually a mixture. The cover letter is written in 1st person.
RE: Passive Voice
______________________________________________________________________________
This is normally the space where people post something insightful.
RE: Passive Voice
But the real subject are the deficiencies:
Many deficiencies were identified at Project site X during an April 19th 2010 site inspection by
MCI (My Company Inc.).
JMW
www.ViscoAnalyser.com
RE: Passive Voice
Perhaps, perhaps not. That's something we cannot know from what the OP has provided. Only the author knows where the emphasis should be.
If the deficiencies are where the emphasis should be, then yes, it should be subject and passive voice would make sense. I think that's in keeping with my suggestion to choose the voice which best represents who/what you want to be the subject to be.
Good Luck
RE: Passive Voice
Nice visual Zdas04! I'll think about that next time I review a report.
RE: Passive Voice
This is the way I was taught as well (large company, EVERY report got reviewed by a senior person); however, grammatically the form is incorrect. It should read "MCI's [highligh]representative[/highlight] has completed a review of...". MCI is an entity. It can't "do" anything. After I became one of those reviewing senior engineers, I routinely bled on such reports, taking out mixtures of personal pronouns in third person, personifications of entities, and verious other grammatical anomalies.
It is unfortunate, but many of the reports I have reviewed over the years had to be re-drafted after grammar and spelling review, so that I could then give it an appropriate technical review.
RE: Passive Voice
RE: Passive Voice
RE: Passive Voice
RE: Passive Voice
Is "easy" being used as an adverb in this phrase? Should it be "easily"?
- Steve
RE: Passive Voice
RE: Passive Voice
- Steve
RE: Passive Voice
RE: Passive Voice
Sort of the 'editorial we'?
Anyway, legally the corporation is a 'person', isn't it?
Jay Maechtlen
http://www.laserpubs.com/techcomm
