Rectangular array
Rectangular array
Rectangular array
I'm trying to make an rectangular array or a pattern face of Extrude (2), but en error don't permit me to produce te result.
I don't want a unite as result.
Where do I wrong ?
Thank you...
RE: Rectangular array
Version?
NX-5 or higher you'd be better using instance geometry. It arrays in only one direction at a time but it doesn't produce booleans.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Hi hudson888,
thank you...your suggestion works fine.
I remember that in NX3, rectangular array on multi-body doesn't create errors as in NX7.
Anyway....it works also if I need an extra feature for the other direction.
Regards....
