Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This forum is the most helpful site I've ever used. I used to use Deja.com; but, this site is better - hands down!..."
Geography
Need an idea of what type of steel would be used for lower control arm
Ashman2k2 (Mechanical)
16 May 10 21:29
I'm looking for a close match for what type of steel such as AISI rating, would be used for this nissan z32 lower control arm as pictured.  All I know is the thickness is about 3mm.
Also any links to lower control arm design would be nice.
CoryPad (Materials)
17 May 10 17:41
It could be a high-strength low-alloy steel (HSLA) or maybe a dual phase steel.  Probably with a tensile strength of around 500 MPa.  You can find SAE standards that cover these steels.
JayMaechtlen (Industrial)
27 May 10 23:55
but, unless you're stamping a replacement, why would you care? Are you trying to determine strength so you can fab a stronger replacement?
Jay Maechtlen
http://www.laserpubs.com/techcomm
Close Box
Join Eng-Tips® Today!
Join Us             Close
