Toolbox part error
Toolbox part error
Toolbox part error
Hi All,
Not sure what happened but my standard Ansi in hex bolt, and heavy hex bolts are coming in all messed up. I never touched the sketch for the head, and I've run an installation repair and I'm still getting the same issue.
Anybody ran into this?
60% of the time, it works every time.
RE: Toolbox part error
Still haven't found a solution to this issue. Anybody experienced this in the past?
if it is only with the particular bolt you should try to replacing the whole ANSI folder or the particular file with another machine's toolbox data.
Did you replaced the Toolbox in your repaired installation??
Cheers
Gurjeet
I don't remember seeing an option to repair the toolbox, but I can try it again to make sure.
I can also try to copy the bolt from another library. Thanks for the tip.
