Load Bearing Capacity of HSS Tube
I've got a situation where I need to raise a 4 legged stand about 5". I am thinking of using 2" wide pieces of 5"x5"x1/4" HSS tube. Each leg of the stand would bolt through the top horizontal surface of the tube, and the tube would be secured to the floor at the bottom with a concrete lag. The stand weighs approx. 2500lbs. How can I determine if the tube is adequate to support this load ?
Jeff
Jeff
RE: Load Bearing Capacity of HSS Tube
http://www.FerrellEngineering.com
FranzR
Jeff
Thank-you
Jeff
