Oxygen piping
Oxygen piping
Oxygen piping
I need the codes and the quality issues concerning oxygen pipes.for industrial plant 'MINING'
RE: Oxygen piping
This is how I would (honestly, I would...) go about this:
1.    Find out if there are any local or governmental statutory / regulatory requirements, failing which -
2.    Re-read the owner's specification as to what code to use, failing which -
3.    Ask a colleague what practice was employed before at the company, failing which –
4.    EIGA guideline for oxygen pipelines is an excellent reference
5.    Self-cogitate and revisit your original reasoning behind the mountain of work you desire to create for a) yourself by using an unfamiliar code or b) sadistically specifying a code, for which your contractor's price is going to be... a tad unexpected , failing which –
6.    Examine the suitably of B31.9 or B31.8 if you must, failing which –
7.    http://lmgtfy.com/?q=design+code+oxygen+piping
