Job submitted but then nothing
Dear all,
can u please help a doctor who has really basic knowledge of Abaqus.
I am running Abaqus 6.8.1 CAE on Windows Vista.
It was working perfectly allright until recently. Nothing new was installed on my computer, no new firewalls etc.
Out of the blue, after I submit a job it never proceeds from submit to run.
The log file says
Abaqus JOB Job-178
Abaqus Version 6.8-1
Socket error: (10060, 'Operation timed out')
Begin Analysis Input File Processor
05/15/10 09:33:47
Run pre.exe
 ***WARNING: Interactive messaging has been requested for this analysis run, but initialization of the messaging system has failed.  Therefore no messages will be sent to Abaqus/CAE for this phase of the analysis.
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens.
Any ideas,
Many thanks
Anarmostos
RE: Job submitted but then nothing
This used to happen on our college network from time to time. The job is probably still running (have a look in task manager for 'standard.exe'). If you look in the .sta file it should still be updating as the analysis progresses.
In terms of fixing the problem I can't help much. I guess there's some conflict with Abaqus 6.8-1 and vista. I did find before when working with CAE on a laptop that turning off the wireless adapter fixed the problem though. Strange but true!
This is the same problem i had two months ago with university pc.
I supposed u use abaqus with Flex licensing utility....this work like a network licensing even if it's installed on a single machine, so if any kind of firewall/OSsecuritySystem stop communication, abaqus/CAE can't show what is appening about running.
Try to check if there's something like that.
Like MechIrl said, the job is still running even if u can't see it in CAE: if u can't fix the problem, u can open .odb when the analysis is finished by setting appropriate working directory in abaqus/CAE.
Anyway, i suggest you to install abaqus over Linux distro...it's easier to control firewall/OSintrusion and use much less ram (it's better to keep ram for abaqus, instead of use it for OS).
Fabio
PS: sorry for my really bad english :)
Guys,
thank you lots! You saved me, as I had not realized the jobs were still running!!!
Good news.
Thanks a lot.
