NX3 ASSEMBLIES
NX3 ASSEMBLIES
NX3 ASSEMBLIES
Friends
I have a problem in NX3, when I try to add a new component in other file with his sketch.
The only way that I found was "eliminating all parameters"., this is problem for me because I need to change some dimensions in the sketch or expression chart to modify my model.
And that way results in use only a "solid part" instead of using a complete body with all parameters "live".
Thanks for your help
RE: NX3 ASSEMBLIES
Do you get an error message? if so what does it say?
It sounds like you might be trying to add a part created in a later version of NX?
RE: NX3 ASSEMBLIES
Cowski
both files were created in NX3, and it doesn´t launch an error message.
RE: NX3 ASSEMBLIES
I'm afraid that you're going to have to do a better job of describing what it is that you're doing and what it is that you expect to happen.  And the part files would be useful as well.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
