316L SS, Al fittings and saltwater
We're having an issue with galvanic corrosion for some of our products installed in locations exposed to salt water. We have large grates made from 316L SS. Attached to these grates is an aluminum (part 2024, part 6061) hose fitting and braided SS hose.
We had installed electroless nickle-plated aluminum fittings, but these have corroded and failed in less than a month at one particular location. We can also get this same fitting with a Type II anodization, but we are concerned about galvanic corrosion between the aluminum and SS. The amount of SS is very large compared to the amount of aluminum on a typical installation. I've attached a rendering of one of our installations.
Would the anodized aluminum be a good option, or do we need to look into other options that will allow us to get a stainless steel fitting?
Any help or advice would be greatly appreciated!
Thank you,
Brandon
Thank you,
Brandon
RE: 316L SS, Al fittings and saltwater
- ALL stainless.
- Stainless and aluminum pieces galvanically isolated by plastic bushings, spacers, etc., typically at least 2mm thick. Anodic coating would theoretically work for this purpose, but it's easily breached and rather thin, so easily bridged by a drop of salt water.
Mike Halloran
Pembroke Pines, FL, USA
Plymouth Tube
