Water Velocity in Schedule 40 Pipes
I am wondering if there are ruel of thumbs to respect for water supply velocity in Schedule 40 pipes? I performed the calculations and the pressure drops are ok but I am just wondering what kind of velocity I should target. I am supplying cooling water to a dynamometer at 750 GPM in a 6" pipe and the veoclity is approx. 8 ft/s. Is this too high? Are there velocity figures that shall be respected?
Gabriel Leblanc
RE: Water Velocity in Schedule 40 Pipes
In relatively clean water service you will be OK at 8 ft/s.
API 14E is the most common guideline that I know of for erosional velocity concerns.  In Imperial units, I think the magic number to not exceed is about 8,000 to 10,000.
SNORGY.
"General rules of thumb" that I've used are (for heat exchangers):
Over 3 ft/sec to avoid corrosion due to MIC; less than 10 ft/sec to avoid erosion.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
I just found the formula and did a calc yesterday for a Hx regarding sediment 150 microns and larger and the required velocity was 10.14 fps to keep it in suspension.  Funny, I can remember that value but I can't remember where I found the formula or what I was doing.
rmw
Now it comes to me - it was from Cameron's Hydraulic.
PPS: Patricia, since we know you work in nuclear and most of that is stainless (or better), 10 fps seems a little low for stainless, huh????
rmw
Wish it was all stainless, but it's not.  Lots of bronze and carbon steel still around.  Seen more than a few heat exchangers where they had to retube.
Patricia Lougheed
Patricia,
OK, now I understand where you are coming from.  You have my sympathy.  (So does your steam generator tubes and turbine blades.)
rmw
