Corrosion effects on structural steel exposed to water
I have an application where I am using HSS to frame a cofferdam. The dam should only be in the river about 6-12months. The steel will not have any protective coating.
Do I need to take into account the reduction in strength due to the steel corroding? Or is the corrosion insignificant due to the short period of time it is being exposed to the water?
Any direction on resources or information would be appreciated
RE: Corrosion effects on structural steel exposed to water
http://www.seashield.com/nace2002.pdf
in freshwater the corrosion is approx the same.
hope this help
S
Corrosion & Rust Prevention Control
Cedar Bluff Engineering
http://cedarbluffengineering.webs.com
