NX6 Annotation Preference
Trying to set a preference for having the default for dimensions to appear "Aligned" with leader/extension lines when ever I start a new drawing.
The current default is "Text over dimension line". I can change this in Preferences-> Annotation-> Dimensions, then the pull down menu on the left in the second row, for a given session. But would rather have it default to that everytime.
Under File-> Utilities-> Customer Defaults... there does not seem to be the option to set this default as I know this is where you go to set things up and retain changes between sessions.
Not sure if I am just not looking in the right place...
RE: NX6 Annotation Preference
Bill
