toolbar setup
toolbar setup
toolbar setup
Does anyone know what I have to do to only get certain toolbars to open with different applications?  Like I want a drawing toolbar that I have created to only open up when I open a drawing.  But it just stays up no matter what I open.  Any suggestions?
RE: toolbar setup
Have you tried adding icons to the existing drawing toolbar? This will show only in drawing mode.
Ed
RE: toolbar setup
To customize your toolbars:
Utilities>Customize screen
Select the toolbars tab
uncheck any toolbars you DON't want to see like drawing.
Check Toolbar1 at the bottom.
Now choose the Commands tab. Select the appropiate category on the left such as drawing and drag the icons you want to the new, empty toolbar you just added.
