Sheet metal limitations
Hello
Is creating a model like the one attached to this post beyond the limitations of sheet metal when it comes to either unbending the part, or creating a flat solid?
Many thanks in advance.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Sheet metal limitations
Mike
If you only had 1/4 of that part it could do it - Then mirror the flat pattern a couple times to get the theoretical flat pattern.
This is probably very much considered either cheating or a compromise that is less than ideal, but it gets you a result.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
