PWHT of Entire Heat Exchanger
We have a type NEU complete carbon steel heat exchanger that needs to be post weld heat treated in it's entirety. I had planned to PWHT the shell and the bonnet, then welding the closing seams and do a local PWHT on them. The tube to tubesheet joints are strength welded.
I have one person in my organization that says I am being too conservative - he says I should put the whole, assembled unit in the furnace and heat it all to 1100 degrees - that the tubes will be OK. I think that any residual stresses in the tubes will deform them and cause problems.
Do any of you have experience PWHT an entire heat exchanger with a set of U-tubes in it?
Thanks!
Thanks!
RE: PWHT of Entire Heat Exchanger
