can you extract U-V grid as curves?
I'm sorry if it's an easy question, but it would be helpful to have for an imported solid model I have.
RE: can you extract U-V grid as curves?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
However, if you only want to see your solid 'displayed' as U/V curves you can do that by changing your display to 'Static Wireframe' and then using the Edit Object Display, set the number of U & V curve in 'Wireframe Display'.
Now if you want actual curves as separate objects, you will need to go to...
Insert -> Curves from Bodies -> Extract...
...and select the 'Isoparametric Curve' button and then, one face at a time, you can select the faces and create as many U or V curves as you wish (I said it was tedious).
John R. Baker, P.E.
Industry Sector
Cypress, CA
I've used it many times when rebuilding tubes and wires from imported data.
Is there an easier way now?
John R. Baker, P.E.
Industry Sector
Cypress, CA
