Saving as Autocad - Setting Layer Linetypes and Colors
Need some help figuring out. I like all my drawings the way they are in Inventor 2010, but I need to export as Autocad 2007 for vendors and suppliers. All my drawings transfer with separate layers, but everything is white and a constant linetype. Right now I manually go into autocad and change all the layer color and linetype settings. Time consuming with close to 100 drawings.
Any way to automate that or set up a template or configuration file?
Thanks!
INV 2010 SP3 64-bit
Windows 7 64-bit
RE: Saving as Autocad - Setting Layer Linetypes and Colors
In my Version 11, I can set a template file in the "save-as dwg" dialogue (There is an "options..." when you are in the save-as dialogue and select .dwg).  At that point, it matches layers that are named exactly the same.
Although I believe the newer versions have native dwg support, so I can't say for sure if that option is still there.
Yeah I have seen that option to do that. I'll have to see if I can get an Inventor drawing to export with all the possible layers to I can set what I want in Autocad.
That did the trick. Created an autocad file with all the same layers as in the inventor file and then links the dwg/dxf out config file to it.
Thanks for pointing me in the right direction.
