How to pass definitions from one file to a new job?
Hi
Suppose I want to pass definition from one job to a new one
Like section properties etc.
Is it possible and what is the way to do it?
10x
RE: How to pass definitions from one file to a new job?
Just rename the model and delete the structure.
Thanks stressed
but when I do this I can not build a model using the wizard from "new model" menu
arboi, you can add and build models from  wizard templates using the Edit menu>Add to model from template using this technique.
Personally, I rarely encounter designs where the templates can save me time compared to working with grids
stressed
Thanks for your good help
