Sesimic Base Shear
Sesimic Base Shear
Here is a very silly question:
When designing a foundation system on piles and caps, do you have to consider the weight of the foundation system and slab load (if used for storage) when calculating your seismic base shear? This base shear would only be used to check against the lateral load capacity of the foundation system (using the lateral resistance of all the piles or the passive resistance of the dirt against the exterior grade beam).
RE: Sesimic Base Shear
p.s. there's no silly question in engineering
