Maxwell's reciprocal theorem
According to Maxwell's reciprocal theorem the displacement at coordinate i due to a force at a coordinate j is equal to the displacement at coordinate j due to a force at a coordinate i.
What if the dispacement at coordinate i is a rotation and at j is a translation?
How can a translation and a rotation be equated?
RE: Maxwell's reciprocal theorem
Isn't this why there are 6 degrees of freedom?
TTFN
setee - I fully understand your confusion. I use reciprocity from time to time at work, or more accurately, I frequently use lack of reciprocity to find experimental errors. To give a concrete example, if I apply a torque TZ to station 1 and measure the displacement Y at station 2, and then reverse the two stations then reciprocity says that in a linear, passive, system Y2/TZ1=Y1/TZ2.
It is a corollary of the superposition theorem (according to Roark), and is closely associated with St Venants theorem.
The example you give is slightly incorrect "What if the dispacement at coordinate i is a rotation and at j is a translation?"
Reciprocity does not apply if you change the type, or the direction, of measurement.
Cheers
Greg Locock
Just consider what we do when we use matrix analysis for any structure (whether 2D or 3D).
We start with [stiffness matrix]*{displacement vector}={force vector}
We quite happily include both translations and rotations in our displacement vector. Similarly we use both lineal loads and applied moments in our force vector, (with applied moments where the corresponding degree of freedom is a rotation).
The fact that the stiffness matrix is always symmetrical is evidence that Maxwell's theorem applies to both types of loads and displacement (linear and rotation).
All that we have to remember is that if a degree of freedom is a translation, then the unit force that is to be applied there is a lineal load. If the degree of freedom is a rotation, then the unit load to be applied is a unit moment.
eg, consider a simple propped cantilever of constant section.
With a vertical point load at midspan, the rotation at the free end is W*L^2/32EI. For a unit load, the end rotation = 1*L^2/32EI.
With a moment applied at the free end, the midspan vertical deflection = M*L^2/32EI, and for a unit moment it =1*L^2/32EI, and Maxwell's theorem is seen to apply.
That was my point: a translation cannot be equated to a rotation.
TTFN
Austim, this means that translation and rotation are equal numerically?
The (vertical)deflection at the free end due to a load at midspan is equal to the (vertical)deflection at mid span due to a load at the free end.
Also
The rotation at the free end due to a load at midspan is equal to the rotation at midspan due to a load at the free end.
You can't muddle DOFs up, which is IRstuff's point (sorry, I thought you were confusing things, you were being cryptic)
Is that clearer?
Cheers
Greg Locock
I'm afraid that before we are done, this thread will have caused great confusion, but yes, your interpretation of my post is entirely correct. You do get the same numeric value whether you calculate the midspan vertical deflection due to "unit" moment at the propped end or the angular rotation at the propped end due to "unit" vertical load at midspan.
I urge you to do the same sort of calculation on any structure you choose, or try unit loads/moments on any pair of nodes in any structural model that have assembled and verify what I say for yourself.
Greg, regrettably I have to say that you are plain wrong.
What you have to do with Maxwell is to ensure that the loads that you apply are matched to the degree of freedom to which they are applied. So long as you do that, Maxwell does not care whether the degrees of freedom are two rotations or two linear displacements or one of each.
The whole point of my propped cantilever example was to show that the rotation at the propped end due to unit vertical load at midspan is numerically equal to the vertical deflection at midspan due to a unit moment applied at the propped end.
Note that I am not saying that a "translation is equivalent to a rotation", just that the computed values are numerically equal. That is all that Maxwell says.
As I have suggested to satee, why not try it out for yourself, on any structural model that you may have. Just try two load cases, each with a single unit load/moment and compare the resulting output displacements. You might be quite surprised by your findings.
I think we should look at Maxwell's theorem from the fundamentals. The theorem is based on not just the displacements and forces but the equivalence of work done.
the theorem states that
' The work done by one set of forces in undergoing the corresponding displacements caused by the second set of forces is equal to the work done by the second set of forces in undergoing the corresponding displacements caused by the first set of forces.'
For simplicity, if you consider only one force (or moment) in eash set, the product of force-1 acting at point A and the displacement at A in the direction of force-1 caused by force-2 is equal to the product of force-2 acting at point B and the displacement at B in the direction of Force-2 due to force-1.
Hence, by making the values of the forces(or moments)numerically equal to unity, you get numerically equal displacements. The equivalence is only numerical irrespective of whether the displacement is linear or rotational.
I am very grateful to you for your post.
One of the things that I have learnt over many years is that there is often no-one more wrong that someone who is quite sure that he is correct. With my certainty that my comments were valid came an uncomfortable feeling that I needed to verify them.
Accordingly, I have just been re-running my basic maths, deriving the deflected curve for a propped cantilever (by Macaulay's method of double integration of the BM diagram, much slower than when I used it in 1954 or so
I was greatly relieved to find that my result exactly matched Roark's formula for the end slope of a propped cantilever with varying location of point load (with the minor substitution of M for W).
My next step was going to be a couple of numeric trials with independent computer programs, and then I would have been ready to sleep. Thank for saving me those last steps
I since you mentioned about work done i would like to come out with a doubt which i have from years.
Now it is said, for a real work done we multiply the load and the corresponding displacement divided by 2.Right?
The reason for dividing by 2 is said to be that load being applied gradually.
I still don't follow that are we applying load gradually?For example consider the spring test we have done in U.G., we do not apply load gradually but just place the mass and as a result spring deflects.Only, thing is that we do not apply load under impact.
Next doubt,
As you mentioned,
"The work done by one set of forces in undergoing the corresponding displacements caused by the second set of forces is equal to the work done by the second set of forces in undergoing the corresponding displacements caused by the first set of forces."
Now both these works done you mention are actually not done by these forces, i.e. "work done by first set of first set of forces in undergoing the didplacement caused by second set of forces is actually done by second set of forces", right?Then why bring this work in expression for work done and give it names like virtual work???
The answers to your questions
1. Gradually applied load does not mean that the load is applied gradually by you. It only means that the load gets transferred to the member from zero to maximum while the deformation increases simultaneously from zero to maximum. It is not the extent of time taken for the load transfer which makes it gradually applied load but the load transfer in proportion to the deformation which gives it the name. In other words, the load-displacement curve is not vertical but is inclined to the axes. The work done in this case is the area under the load-deflection curve which is a triangle (for linearly elastic behaviour)and hence the division by 2 for the work.
If you consider a body already loaded with a load P1 and an additional load P2 is applied to the body, the additional deformation under the load P1 will occur with P1 acting fully through the deformation. The additional work done by P1 in this case is the product of P1 and the additional deformation (no division by 2).
2. Regarding the virtual work and virtual displacements indicated in the reciprocal theorem, these are concepts developed to derive certain relationships among the structural parameters. Thay need not occur in reality.
Consider a spring loaded by a weight W (gradually or suddenly). The spring will deflect by a distance say D. At any moment when the sping is deflecting from 0 to D, the deflection of spring will be Dt where 0<Dt<D. Now how much force the spring is exerting? It is K*Dt, where K is the spring constant.
So you see the spring reaction rising linearly from zero to KD. The area of this triangle is obviously (KD)*D/2. In other words, W*D/2, which is the potential energy of spring at the moment. Since this is a triangle, you see a factor of two there.
Let a and b be any two points in a linear system. Let the displacement of b in any direction U due to a force P acting in any direction V at A be u, and let the displacement of a in direction V due to a force Q acting in direction U at B be v. Then Pv=Qu
So "The (vertical)deflection at the free end due to a load at midspan is equal to the
(vertical)deflection at mid span due to a load at the free end."
is correct
"The rotation at the free end due to a load at midspan is equal to the rotation at midspan due to a
is wrong. aaagh. sorry.
Cheers
Greg Locock
please don't forget Austim's Nth rule of engineering - Don't believe anything you are told unless you can verify it somehow. If you haven't already run your own numeric verifications Please do so.
That would be a much more satisfactory conclusion than simply being bludgeoned into changing your belief by some anonymous Australian engineering fundamentalist that you have never even met.
Cheers
Greg Locock
Trilinga you mentioned-----"In other words, the load-displacement curve is not vertical but is inclined to the axes----."Should'nt it be "horizontal"(usually with load on x-axes and displacement on y axes)?Hope i am not wrong!!!!!
Flame,
The spring deflects because it is first in a state of unstable eqilbrium and then gradully when it reaches a state of stable equilbrium it stops deflecting.As the load is getting transferred, simultaneouly spring is aquiring equilbriting force , the reaction in the spring is at any instant the amount of load transfered.
So the multiplication of the spring constant with the displacement should be done only when the spring stops deflecting not at any moment when the sping is deflecting from 0 to D.What i am trying to tell is , that , is the theorem of potential energy related to the reason for division by 2.Is'nt the theorem of minimum potential energy only an explanation for stable/unstable equilbrium?
Trilinga please comment
I have considered the load - deflection curve with deflection on the x-axis. This is the normal practice since deflection is taken as the independent variable since it is observable and independently measurable.
Flame's explanation is right. Read his post once more. Flame is not referring to the displacement of an oscillating spring which comes to static equillibrium after some time. that situation corresponds to a dynamic or impact loading whose equation of equillibrium is different. What is referred here is a static loading on the spring which deflects gradually and reach the maximum. The condition 0<Dt<D mentioned in his post means that. He has considered the load transfer proportionate to the deflection under static loading.
I am not clear about the last part of your question regarding the potential energy. Can you elaborate?
Sorry, Flame if i got you wrong.Appologies!!!
Trilinga, according to the theorem of minimum potential energy th structure is in equilbrium if no change occurs in total potential energy of the system when its displacement is changed by a small arbritrary amount.In case of the spring above , is the spring in a state of stable equilbrium throughout its course of deflection from 0 to D.??
I would like to modify one of the statements in my previous post. In reality, there is no load transfer that takes place completely static. Any load that is applied to a system causes a disturbance to the system and makes it respond to the change. The system undergoes a time varying deformation before it 'settles down'. During this transient phase, the system is governed by the equation of dynamics. The governing equation reduces to the equation of static equilibrium once the dynamic components die down.
So, the spring is in equilibrium even during the moving phase but is governed by a different equation.
However, we reckon the response as static or dynamic depending on the time taken by the system to get rid of the 'ripples' and come back to static equilibrium. For a system recovering fast the response will appear more static.
I can state a very common example. You observe a sequence of ripples on the surface when water is poured into a bowl. But the surface looks practically undisturbed while pouring a very viscous liquid like lubricating oil. The dynamic disturbance is absorbed immediately due to the viscosity of the liquid and the dynamic phase is unseen.
The minimum energy principle is common for both static and dynamic problems. It defines the unique displacement configuration, which keeps the system in equilibrium.
For a static system, it is stated as :
‘Of all the displacement configurations which satisfy the boundary conditions, the one which minimizes the potential energy keeps the system in stable equilibrium.’
In case of your spring example this yields the equation
stiffness *deflection = applied force
or k*v = P where v is the deflection.
For a dynamic system the same principle is stated as :
‘Of all the time histories which satisfy the boundary conditions and also the initial and final conditions, that which makes the term (Kinetic energy – Potential energy) a minimum, will keep the system in equilibrium.’
the equation in this case becomes
m*d^v/dt^2+C*dv/dt +k*v =P(t),where v is the time varying displacement
You can refer to any standard text book which will show how the minimum energy principle results in the equilibrium equation.
Hope I have not deviated very much in answering your query.
Can we say that the spring deflects because it has to reach from the state of unstable equilbrium to stable equilbrium?
The load gets teransferred gradually in increments.During each increment the spring has to reach from the state of unstable to stable equilbrium.Suppose the deflection in the spring at an increment is Dt, work done is (K*Dt)
Finally it is K*D.
The reason for division for 2 is load getting transferred in increments, the theorem for minimum potential energy is merely an expalnation for unstable/stable equilbrium but provides some insight to work done.
Stable equilbrium is raeched when spring stops deflecting.
It is NOT unstable equillibrium since the stability is NOT lost during the motion of the spring.
The fact that there is motion in the system does not mean instability.
It is only a change from a state of dynamic equilibrium to a state of static equilibrium.
Througout the process of load transfer the equilibrium is not affected. An unstable system such as a three hinged beam has no capacity to transfer load to the support and hence it collapses, whereas the spring at any moment is transfering the load to the support.
Mathematically an unstable system will have a singular stiffness matrix. The spring we talk about along with its support has a finite non-zero stiffness and hence the whole system (spring along with its support)is stable.
The system comes to rest by keeping only the minimum energy and dissipating the excess energy during the oscillatory motion.
Trilinga
Can we say for a completely rigid system that will not deflect during loading(just imaginary) the entire energy would be strain energy (not divided by 2)?
Forgive me if I sound a little curt but I mean absolutely no offence.
I sincerely feel that you have been using different terms without fully understanding what they mean. My friendly advice to you is to brush up your fundamental concepts by reading a standard text book on structural analysis.
Thanks for your suggestion!!May be, i am not as intellectual as you are, also i would not have been fortunate enough to have a set of faculties in school as i think you would have had.Also, i know my thoughts are not as clear as they should be in structural anlysis but still i aim to make the best possible.I am currently reading books, and try to involve in discussion groups like these to get an insight into how others think of a physical phenomenon to shape myself into coorect thinking.I sincerely feel that no doubt is stupid once asked .
I am extremely grateful to you for having bring patient enough to answer my queries and having dealt with a person who probably may be having 1/1000000 intellect of yours.
My intention was never to discourage you from asking questions since I developed my understanding only by asking a million questions when I was young. It might be true that the masters of yester years were extremely patient with us in answering our questions which people like me have to learn yet.
I strongly believe that the term intellect is an invariable entity residing in every individual which has no relative measurement. What we require is the faith in it and start applying in the right direction. I learn a bit more everyday from evryone I come across and at times get astonished by the excellent ideas and explanations on structural behaviour from my juniors.
Believe it, knowledge is a sweet ocean and we are fed with drops of it every now and then by nature.
My post was not born out of frustration on the stupidity - you said so and I never thought it was - of your last question, but on the lack of clarity and direction in it. It may be just my feeling and I may be wrong. Hence I felt it would be better for you to get the direction by refering to some good authors who have explained these concepts with clarity. (Do not ask me who the best author is but find out)
Good luck!
You mentioned:
"I developed my understanding only by asking a million questions when I was young."
I am still young , having finished my courses last year.But then i lack clear ideas anh hence my questions do lack clearity.
Then you said:
"It might be true that the masters of yester years were extremely patient with us in answering our questions "
Well, to be frank(not exagerating) when i asked questions to my teachers in school few times i got excellent replies but most of times i was turned down in a way not to ask .
questions again(God only these reasons, perhaps my teachers lacked the ability).In this case you were not as unlucky as i have been, i suppose.
Then you said:
"I strongly believe that the term intellect is an invariable entity residing in every individual which has no relative measurement. What we require is the faith in it and start applying in the right direction. "
This is what i have been trying to do but i am yet to find the right direction!!!!
"I learn a bit more everyday from evryone I come across and at times get astonished by the excellent ideas and explanations on structural behaviour from my juniors."
This is what i feel when i get replies to my questions from this site . It makes me happy at times to get my answers at the same time makes me feel down too when i look at my thoughts.
"My post was not born out of frustration on the stupidity - you said so and I never thought it was - of your last question, but on the lack of clarity and direction in it. "
I fully agree here."
Appologies!!!
"Hence I felt it would be better for you to get the direction by refering to some good authors who have explained these concepts with clarity. "
I am currently reading books, in whatever time i get from my work.These are
1)Elements of Strength of MAterials(Timoshenko and Young)
2)Intermediate Structural Analysis(Wang)
3)Theory Of Structures(Timoshenko and Young)
Few indian authors which probably you might not know:
3)Structural Analysis(Pandit and Gupta)
Thanks , Sir.
Glad that you have been reading real good books. I was reading other Indian authors like Ramamrutham and Vazirani for analysis.
Remember, whoever be the author you are reading, try to visualise and try to link the associated mathematics with the physical phenomenon and do not give up until you get convinced of the behaviour.
