Import IGES assembly into NX 7
I'm coming from IDEAS 12 and playing around with NX 7.
I want to import an IGES file and have the parts come in as an assembly. Working in IDEAS, I did this by importing an IGES file created with the "All Layers" option turned on and a tailored options list. This method doesn't seem to work in NX 7.
The only way I can currently get the whole assembly in is to import an IGES file created with the "Flat" option turned on, then manually go through and tell it which bodies to make into parts. This is pretty tedious since I have to rename everything.
Can anyone give me some pointers on how to do this in NX 7?
Thanks in advance.
Thanks in advance.
RE: Import IGES assembly into NX 7
But my log file shows that there are some errors with the IGES files or geometry... not really sure what to make of it. It seems to import into IDEAS just fine, so don't know why NX has a problem with it.
Copy of log file:
IGES to UG
! INFO- NX V7.0 / IGES Specification 5.3
! INFO-
! INFO- Start of Translation: 11-MAY-2010 12:10:06 PM
! INFO-
! STATUS- Converting Part: J:\Medusa\Design\LRL\Obtained_20100507\Design\LRL_SOLIDS_AllLevels.igs
! INFO- PTC IGES file: LRL_SOLIDS_AllLevels.igs
! INFO- IM1120 Entity Type 416 Form 1 is not supported.
! INFO- All entities of this type will not be processed.
! INFO-
! INFO- IM1120 Entity Type 406 Form 12 is not supported.
! INFO-
! WARNING- IM1146 The PD section of Entity Type 308 Form 0 at DE# 93
! WARNING- points to invalid DE# 91.
! WARNING- IM1146 The PD section of Entity Type 308 Form 0 at DE# 285
! WARNING- points to invalid DE# 283.
! SUMMARY-
! SUMMARY- Summary of Supported IGES Entities in file
! SUMMARY-
! SUMMARY- Entity Type Count
! SUMMARY- ----------- -----
! SUMMARY- Trans Matrix (124/0,1,10,12).: 28
! SUMMARY- Subfigure Definition (308/0).: 22
! SUMMARY- Subfigure Instance (408/0)...: 28
! SUMMARY- Color Definition (314/0,1)...: 44
! SUMMARY- -----
! SUMMARY- Total 122
! SUMMARY-
! SUMMARY- Summary of Unsupported IGES Entities in file
! SUMMARY-
! SUMMARY- 416/1........................: 22
! SUMMARY- 406/12.......................: 1
! SUMMARY- -----
! SUMMARY- Total 23
! STATUS-
! STATUS- Converting to Output Form (Phase 2 of 3): 11-MAY-2010 12:10:06 PM
! STATUS-
! WARNING- CV1302 Subfigure definition contains no valid entities.
! WARNING- Entity Type 308 Form 0 at DE# 93 not processed.
! WARNING- Entity Type 308 Form 0 at DE# 285 not processed.
! WARNING-
! STATUS- Creating the UG part (Phase 3 of 3): 11-MAY-2010 12:10:07 PM
! INFO- Filing Part ..: D:\Users\AndyMcEvoy\Medusa\NX\LRL\LRL_SOLIDS_AllLevels.prt
! SUMMARY-
! SUMMARY- Summary of Unigraphics Input Entities
! SUMMARY-
! SUMMARY- Entities Processed Count
! SUMMARY- ------------------ -----
! SUMMARY- Part Attribute ..............: 9
! SUMMARY- -----
! SUMMARY- Total 9
! INFO-
! INFO- End of Translation: 11-MAY-2010 12:10:07 PM
! INFO-
I think I had trouble back on NX5 trying to open IGES files with the Open command. Have you tried starting a new file and importing an IGES?
Work does not want to switch to NX7 yet, because of the TeamCenter we are running, but I will try to help.
Adam
but all my attempts were with a new file and using the file/import/IGES command. Once I get back I'll be calling tech support, since as my second post shows, it looks like their translator has a problem since the 416 and 406 forms seem to reference assembly commands.
I'll update my post when I find out more.
Thanks for the help.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
wasn't aware of these tools, but I don't have this IGES file as an IDEAS model, it's coming from a Pro/E model (we don't have the Pro/E translator).
John R. Baker, P.E.
Industry Sector
Cypress, CA
My advice is to contact GTAC with your issues and they will put you in contact with people who know the ins and outs of the various translation products.
As for my comment above about the Pro-E translator, that's simply because I offered to test that exact issue for an old friend who was being asked to soon having to mix and match NX and Pro-E data and he was looking to verify what worked before they invested in additional software and I was simply doing his a favor. The test worked to his satisfaction and that was the extent of my involvement. Granted, once in awhile I have to import something into NX from somewhere else, but it's pretty mundane stuff most of the time.
John R. Baker, P.E.
Industry Sector
Cypress, CA
