assistance needed
assistance needed
assistance needed
I am in the process of installing new sulfuric acid piping and storage system in a alumina production plant,and I would appreciate any guidance on material selection and the best pump to overcome a head of 50 feet, the ambient temp is about 40C.
RE: assistance needed
B8K!
In our sulphuric acid plant we used to have centrifugal pumps made up of CF8M and with carbon steel piping.
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
Check some of the mfr's - GIW Industries has a white iron T90 that works in high corrosion applications
www.giwindustries.com
let THEM do the pump selection work for you!!
Keep the wheels on the ground
Bob
showshine@aol.com
Depends on the concentration of H2So4 and the temperature
PVDF Diaphragm Pump with PTFE Elastomers would probably be fine
Don't ever let a vendor do an engineers job and size the pump for you...   what a world....
