Help on ASME-STS1 in regards to steel stack design.
Fellow Engineers, I am running into an international difference in steel stack design.
Per the ASME, STS-1, Section 4.4, Eq 4-6, allowable stress cases are only valid when equation 4.6 is satisfied.
4-6 states that t/D <= 10Fy/E
basically, it limits your thickness based on diameter as Fy and E are going to be constants in my design.
The issue is in design of something like a 1.2M Diameter steel stack that is 40M high (free-standing). Per the above formula/condition, i cant use plate thicker than 15-16mm (after corrosion @ FY=34ksi & E=29Mill) and with that parameter i cannot design the stack to pass the allowable stress cases.
Our foreign counterparts design the above stack with most thickness around or over 20mm over the lower half of the stack.
Before i can debate which method is acceptable i have to understand why on Earth the ASME would be limiting thickness based on D in steel stacks.
The only thing i can possibly think of is that the rolling of thicker plate to smaller diameters could compromise the steel??? If this was the case i would think there would be thorough documentation on the subject. This also apears to not be the case as FY is on the right side of the formula (stronger steel would allow larger thicknesses... not likely a rolling issue)
Im striking out finding anything explaining equation 4-6. Can anyone offer any advice or interpretation?
I guess the basic question is: What do you do when equation 4-6 is not satisfied?
Am i mis-reading something here? I have brough this issue to 3 or 4 of our senior US structural engineers and they have all be puzzled by this (mostly by the fact that they havnt noticed this stipulation in previous designs..)
Why on earth would ASME limit MAXIMUM plate thickness by diameter??
Thanks and Best regards.
RE: Help on ASME-STS1 in regards to steel stack design.
Section 4.4 of the ASME STS1 is for "Allowable stresses"
The first sentance in 4.4 is as follows: "The following formulas for determining allowable stresses are applicable for circular stacks and liners provided that eq (4-6) is satisfied.
They are as follows
Case 4.4.1 (Longitudinal Compression)
Case 4.4.2 (Longitudinal Compression and Bending Combination)
Case 4.4.3 (Circumferential Stress)
Case 4.4.4 (Combined Longitudinal and Circumferential Compressives Stress)
4.4.5 moves into stiffeners.
My company desings (and has designed) steel stacks by the above 4 cases for years.
In front of 4.4.1 is the following "For Stacks and liners meeting the requirements of eq. (4-6), the following four load cases must be satisfied."
Again, what do you do when 4.6 is not satisfied? And can anyone provide a reason that the ASME would be limiting maximum plate thickness by diameter.
The stack in question is outside of our "normal design" in being so tall and slender, but i have a hard time just going with our forign design while not understanding this ASME stipulation.
The t/D ratio is most certainly a plate/shape buckling criteria, or limit, probably somewhat subjectively (arbitrarily, the 10?) set, by ASME. D and t are intimately related in this type of buckling problem. Theory might indicate slightly different limiting values of t/D for different load combinations. What circumferential stress do you expect? Do they mean a torsional loading or a pressure one way or another, or dynamic loads? Do you need strakes on this stack?
I don't have ASME, STS-1, so I don't know exactly how they treat each of the load cases. Certainly, the design stresses for each case must be less than Fy of 34ksi, and are a function of t, D, rad. or dia., length and E. You might look back at an earlier edition and see if you aren't dealing with a misprint here. The equation you show as (4-6) seems bass acwards to me, the 'less than' symbol should be pointing the other way. Given a 'D', I would expect 't' to have to increase as the design stress increased to guard against buckling. I'd look at plate, plate arch, pipe, pipe column, shells and the like, for discussion on buckling stress limitations. My first look would be a number of Timoshenko books or Roark. I'll try to look a little deeper later, if I don't see any more activity on your thread.
Your back-asswards thoughts are exactly what the senior structural guys i talked to thought, but reversing the signs would make less sense as it would be setting a required minimum thickness of 14-16mm...
Keep in mind, this equation has no relation to loads, height, wind, eq, ect. It is purely D to t. (which is why it makes no sense to me!)
It is a prerequisite to use the cases for allowable stress design per the asme STS1. Those cases solve for a assumed t with trial and error to get your correct thicknesses as the results. (And here is where the above mentioned Loads, height, wind, eq, ice, etc all come into play)
We have the cases automated with excel and STAAD and I can see that the thickness provided by my European colleagues (of 20-22mm) are required at the base for this stack to pass design. The problem is... Equation 4-6 says i cant go above 16mm when using the design cases that result in a requirement of 22mm...
Confused yet? I and many other in my office are. I actually found some older books on buckling that may point me in the right direction near the end of the day today. Ill take a look at them tomorrow.
Thanks for your reply.
Michael.
Timing has a lot to do with the outcome of a rain dance.
I wasn't saying you made a typo., but I still think your second para. is wrong, us old guy's agree ASME has it bass acwords. I have never seen a situation where thickening a plate made a buckling problem worse, at a given stress level, unless it changes the buckling from one mode to another, and their cases are based on the former. Setting a max. thickness of 16mm, just makes no sense. You say your own calcs. confirm that you need 22mm from the stress standpoint. Although, Fy = 55ksi, and t = 22mm would apparently make everything just fine. Are they trying to force you to use a steel with an Fy way higher than the design stresses dictated by buckling with their eq. 4-6?
I think you should call ASME and find out who's on the committee that works on that particular code. Get in touch with a couple of them, and find out what their take is on this conundrum, because you and all us old guys don't understand the rationale, and we want to know. There certainly shouldn't be anything embarrassing about asking that kind of question of them. Now days, you can't trace three quarters of the stuff in the codes, their formulas, factors, limitations, etc., back to a simple, logical, apparent, or theoretical and tested basis.
paddington, speculate away, he will need these types of ideas as he goes to ASME. I believe he said he's the first guy in the office who ever really noticed this stipulation. It certainly isn't a rolling issue in the 1.2M dia. and 30-40mm thick range.
"At Yield point for mild steel FY =36 KSI the limits are:"
92< D/t < 361
It also references that the AISI recommends eq 2-10 that states F_allow = [662/(D/t)] + .399FY
This is interesting to me bc it appears that when D/t reaches the lower limit (92) the math shows it is very close to .6FY
662/92 + .399(36) = 21.559 KSI
.6 (36) = 21.6 KSI
(The math shows that as D/t lowers past 92, the allowable grows past .6Fy)
For obtaining valid D/t ratios for other strengths they offer the bounds as
3,300/FY < D/t < 13,000/Fy
I know i had seen the 3,300/FY before and that lead me to the AISC (9th) Table B5.1 (limiting width thickness Ratios)
They match 3,300/FY as the "limiting width thickness Ratio" and for circular hollow sections, width.t.r is defined as D/t
I must run, and am still working through this with about 4 books open on my desk. I do not know if it means .6fy is acceptable as my allowable in this case... One issue with that is the ASME cases we use to check thickness.
Something in the bounds of 92 < D/t < 361 but close to the bottom calculates (im my particular case) out to an allowable of around 10 KSI (per the asme stress checks). Increasing plate 2mm to move beneath the lower bound would give me .6(34) = 20.4 KSi allow and that difference doesnt seem logical.
Must go, but perhaps this will spark your thoughts.
if nothing else, this is interesting and educational.
Thanks!
BR
Hoots
Troitsky is saying .6Fy is your max. design stress in any case. AISC's .67Fy assumes compact sections and all that good stuff, which you certainly don't have here. Your allowable stress to prevent buckling will be less than .6Fy, and more so as t/D gets smaller, and you approach a flat plate. Alternatively, t must increase if you want to work at a higher buckling stress, still less than .6Fy. Again, t/D relates, in some fashion, to the stiffening effect of a smaller dia. wrt the thickness of the pl.
If you forget about the less-than symbol for the moment; ASME's eq. 4.6 [ t/D = 10Fy/E ] looks an awful lot like Troitsky's eq. (2.13) [sigma cr = (.6 gamma) E (t/R) ]. And, I suspect that your FY should really be F gamma. You see this very typo. on the abscissa of Troitsky's fig. 2.5. Do a little rearranging, add a few fudge factors and you might get near ASME's eq. I still think this would be a real interesting question to ask ASME.
Now I have to stop and read chap. 2, look at a few of my other ref's. again, and see if what I said makes any sense.
Found this in Gaylord and Gaylord, 1968 edition. Attributed to Ernest A Dockstader, retired Chief Structural Engineer, Stone & Webster...
"For A36 steel, the allowable stresses due to dead load plus wind or earthquake are 12000 psi for d/t <or= 200, and 2400000/(d/t) for 200 < d/t < 600".
My head is spinning..
Gaylord & Gaylord, Struct. Eng. Handbook (3rd) -1990
page 30-8 (Chimneys)
Steel stacks
9. Allowable Stresses: The allowable longitudinal compressive stresses due to vertical load and and bending moment can be determined by:
(14): F =XY
X is broken into 3 ranges
0 < t/R < 8F_gamma/E
8F_gamma/E < t/R < 20Fy/E
t/r > 20Fy/E
at 1180mm D, 590mm R, 20mm t, im in the 3rd case
20/590 > 20(34)/29000
.033 > .023
This lists X as .5Fy
Y is the exact same calculation as used in the STS-1 cases.
Im my calcs it is .43.
This is tellig me that my allow is .43(.5)(fy) or .22Fy
7.3 KSI ???
This makes no sense to me. When you reach the boundry (in the original 4-6 ASME eq) your F_allow drops as your plate thickness increases???
In rough numbers at 1180mm D, the thickness / allow are:
6mm - 3746 PSI
8mm - 8369 PSI
10mm - 9407 PSI
12mm - 10180 PSI
15mm - 10843 PSI
20mm - 10623 PSI
24mm - 9254 PSI
30mm - 5213 PSI
(Per the ASME forumlas, allowables would be lower for 20-30mm plate using the above Gaylord calcs.)
the curve peaks right around 16mm which is exactly when eq 4-6 does not pass.
Does this make sense? at a constant diameter, how can increasing plate thickness reduce allowable long, compressive stress?
Dhengr, im still looking for some of your other references and the number of my coworkers who are puzzled or interested by this is growing daily...
We are starting to have some real concerns with our international designs that do not address this issue.
Your losing me, because I don't have the ASME spec. your keep referring too. Download a few pages of that so I can see what they are doing, and what their formulas and load cases look like. I do have the same Gaylord & Gaylord, Struct. Engr. Handbook that hokie cited, and I see that I've actually used that in design, about 25 years ago. Your 3rd. ed. will obviously have later research and testing as its basis, download a few pages of that too. My other ref's. had nothing practical, they all had math that would blow your mind and got me to Troitshy's figs. 2.2 & 2.4 in theory. I was hoping to see a chart or graph of R/t vs. bucking stress or some such.
I have seen the form of F = XY, which I think came out of the Univ. of Ill. in the early 1930s. But, I doubt that it's the same one you are looking at, which I understand you see in Gaylord's book. I don't know what your gamma is, I can't see it from here, but again we see [8F(gamma)/E ] as a limit; 8 instead of 10 now.
This particular buckling problem is so susceptible to any imperfections in the shape and loadings during testing, that no one has been able to do a test which approaches the theory very well. Thus, most of the design approaches are based on empirical eqs., with theory in mind, but to match the testing more closely; with fudge factors, etc. based on experience, added. I don't think testing ever comes up to the theoretical buckling strength. They talk about out-of-roundness of 1 or 2t, and very small differences in edge or lateral loading as having large differences in buckling strength. Thus the large difference in empirical approaches, different guy's best guesses.
The extremes of your buckling problem are: (A) flat pl., on edge and edge loaded, a very large D/t ratio; (B) a 12" round pipe with t = .5", acting as a canti. col.; and we think we have a fair handle on these two extremes. Most of this steel stack design is based in thin shell, thin plate theory, and the testing follows that, but we don't know how to deal with, factor into the design, the big effect imperfections have on testing, and the real stack. There will be a blip in our design criteria, and in our design approach as we move from one theoretical regime, or buckling regime to another. But,t = 16mm and D = 1200mm, seems an arbitrary point to me. Again, armed with what you have I think you should talk with ASME, and/or the foreign agency.
Thanks again for the help and opinions. I think you are correct about contacting ASME about this, but im still hoping im missing something obvious here..
BR
Hoots
Notice the reference and similarities to the ASME.
BR
Also, if you get a chance to review the Gaylord scan, it appears that they do have formulas for all cases of D to T.. and as i explained above, it would limit me to something like .22FY as my allowable when using thicker steel...How can thicker steel have a lower allowable at a constant D?
I feel like i have to be missing something here!
Please let me know if the following reasoning makes sense
When equation 4-6 is not satisfied design as follows.
1. Allowable Compression (per AISC 9th)
Table B5.1 states that the limiting width thickness ratio is D/t < 3300/FY for a compact section.
when EQ 4-6 is not satisfied, D/T is within the limit width thickness ratio of a compact section.
In checking for compression, eq (E2-2) AISC 9th is now valid
Fa = (12*PI*E) / 23*(Kl/r)^2
This value will be very close to the allowable yield stress (in regards to compression) from table C-36 which deals with slenderness (Kl/r)
These numbers are also close (but more conservative) than the above gaylord calculation of Fa =XY (The difference could be in safety factors as well as gaylord uses a factor of 2)
So now P/A < F_allow is satisfied for compression. (In reviewing the issue, compression was never the problem... it was the combined compression and moment)
2. Long. Compression and Bending
F.3 Allowable stress: bending of Box Members, Rect. Tubes and Circ. Tubes (AISC)
Eq (F3-1)
Fb=.66fy
This does make sense in reviewing the asme code. (attached a few posts up)
Ks becomes 0 (or very close to it) when eq4-6 is not satisfied because at the lower bound it becomes a negative number. In this case, at 1180mm D, a thickness of 13.8mm is the cutoff for eq 4-6.
Solving for Sbl in the asme (allowable combined long. Comp. and bending stress) we are directed back to eq 4-9. Sbl = Fy (1-.3Ks)Y / F.S. (Y becomes 1 as noted in case 4.4.2, F.S = 1.5 per table 4.4.6)
We are left with Fy*(1-0)*1 / 1.5 or 34/1.5 = 22.66 KSi
.66fy = 22.44 Ksi.
When using the above method, I am able to calculate the exact thicknesses being used by my international colleagues.
I have run this by my senior guys and in the local office, and while a few want to think about it for a while (I know... imagine that!), there has not been any alarms set off by this method.
Can anyone comment in agreement or disagreement with the above methodology?
Thanks and BR
-Hoots
P.S. – I kept having a hard time understanding lower allowables on thicker steel, but once I started thinking of the stack as a "slender column" it was like a bell went off in my head.
Call the guy who does the STACKDES program and ask him. He's probably the most knowledgable guy with regard to stack design.
By limiting t to 16mm for your dia.; I wonder if they aren't saying, 'any thicker than that and you are no longer working within what we consider the thin shell regime, certainly stiffer than any of our testing, so these allowable bucking stresses may not actually apply.' I would not ignore ASME's stress formulas, and it sounds like you haven't since you said you needed about 22mm to meet them. So, maybe they are saying that given your D/t, you are working below the lowest D/t values considered for these testing programs and for these empirical formulas. Above t = 16mm, you are moving out of the thin shell regime; into a no-mans land, a long way from the 12 or 16" round col. though. Does that ASME STS1 code have a commentary you should be looking at and telling us about. Or, as paddington suggested any discussions of the standards in journals, prior to adoption.
The ASME limitation is because you are moving out of their known range of, thin shell, thin plate, elastic bucking regime for these cylinders, as you increase t too much. Their formulas are for thin shell, elastic buckling, and the thicker pl. will push you into another buckling regime, if buckling happens at all. The tougher problem may be making this stack check as a canti. beam/col., where kl/r = 2l/r, for Euler type buckling. It seems to me that you are working at such a low D/t level that you just won't get their, thin shell, kind of buckling, if you get any buckling at all. We should maybe looking at another form of buckling for these kinds of cylindrical structures, and that is that they can go into a flatter, or oval, shape. Maybe we should be looking at the fact that the actual max. stress which might cause buckling only occurs over about a 90° arc of pl. at any given time. I just don't see that thickening the pl. and working near (or to be within) their stress ranges leads to a buckling problem.
What do the power transmission people do with their towers? They are break forming their poles in 8, 10 or 12 sides, certainly as tall as your stack, and with much higher imposed loads and moments. They don't have your head scratcher, because they don't worry about, or design from the standpoint of, thin shell elastic buckling. They undoubtedly do pay some attention to pl. buckling, the way we normally look at it, but they have the advantage in that they think in terms of stiffened edges on a 10 or 12" wide pl.
I wrote the above before I saw the ASME & Gaylord mat'l. you sent. I think you're on the right track now. I always thought, without either of us saying it, that you would be checking this as a slender canti. beam/col., with kl/r = 2l/r, and an interaction equation, and that that might control the design. But, I didn't see your ASME approach until late yesterday. I'm not so sure that I would be so bold as to say you have a compact section (.66Fy) with your dimensions though; but you are below their D/t range for thin shell theory and testing. AISC doesn't comment on non-compact sections in their table B5.1, because pipes are a nice stable shape and most dias. we deal with are probably compact. But, see their footnote 'c' and appendix B5, pg. 5-100 and there-abouts. In your 4th para. under (1.), 'allowable yield stress' seems like bad wording, and what is table C-36?
It just took TERIO, with few words, to turn on the light bulb. In effect, the above is about what I meant when I said you are moving out of the thin shell regime, but into something of a no-mans land, since this sure isn't a 16" round pipe col. either. Thanks TERIO!
In most buckling problems, you are always looking for a min. thickness, a width/thickness or dia./t criteria for a given stress, to prevent buckling. So, it shouldn't be hard to wrap your head around this, but it's a min. t for a given width or dia. at a particular stress. ASME is saying if you go above this t/D these stress equations are suspect as you are moving out of the thin shell regime. And, we have been arguing this back and forth through this whole thread. And then, just to confuse things every other formula or graph uses t/D instead of D/t or R/t which tends to do funny things with your thinking and the inequality symbol.
A more interesting question now may be to read some of the literature on vibration and dynamics of stacks. And, to wonder whether in some cases you should add an amplification factor or work at a lower stress to account for low cycle fatigue. For both of our, all of our edification, I would like to know what the ASME committee says on this. With a little more digging and work, you and I could teach a seminar or semester course in steel stack design.
Yes, my wording was poor in regards to table C-36. (Page 3-16) Allowable Stess for compression members of 36KSI specified yield stress steel.
I mentioned this as a "common sense check" in that my allowable at Fy=34 using equations E2-1 & E2-2 from the AISC is close to the numbers provided by table c-36 for 36KSI steel with a Kl/r of around 172. Gaylord's Eqs return similar results
In hindsight... It seems this was a not seeing the forest bc of the trees issue.
I (and other coworkers) stared at the line about "all other steel members shall comply with the requirements of the AISC..." but we all were thinking of "members" as stiffening bars, or part of our breach design, or spoiler (strafes) designs or pieces in our compression rings... Some still question this line, and feel it should be addressed by the asme.
The biggest curve ball, to me, was no mention or relation to slenderness in equation 4-6. The pure D to t ratio is what was throwing me off. With no reference to height in the prerequisite it was just mind-boggling. (and threw many off us off in the wrong direction)
Now, it appears, (to me) that equation 4-6 is determining if you can use AISC design methods shown in chapter E (Columns and other compression members) or if you need to use the ASME equations. (ill need to use both in this case as our plate with range from 22mm at the base to 6mm at the top)
I do plan on asking ASME about this issue. One of our Engineers asked the following in regards to legality
Can a stack with with a t/D not meeting equation 4-6 be designed per the ASME code? (basically, my same original question... What do you do when Eq 4-6 is not satisfied)
If the answer to the above is yes, what design method is acceptable.
Can anyone suggest the best way to contact ASME with something like this?
ht
Dear Mr. XXXX
Please see below in bold letters the personal opinion of a committee member. Please note that since this is the personal opinion of a committee member, it is not endorsed by ASME.
If you require a formal written interpretation, you must follow the guidelines noted in page vi (correspondence with the committee) of the Standard. I could take about 2-3 months to get an official response.
Sincerely,
XXXX XXXX XXXXX
Project Engineer
ASME
Three Park Avenue, MS 23E4
New York, NY 10016
Tel. (212) 591-8018
Fax (212) 591-8501
(This is my original email with the ASME response in brackets)
Mr. XXXX
My colleagues and I have been requested to estimate and design free standing steel stacks that do not satisfy equation 4-6 (ASME STS-1-2006). (As an example, a 36.7M tall stack by 1.18M Diameter). Once stresses are calculated, the design would require 20-22mm plate at the base. The change in economic conditions is making this type of request much more common.
[Response: I'm not sure why the thickness is so high (20-22 mm). This is a very slender stack and I can imagine that wind induced vibration (vortex shedding) may be controlling the design. Usually you would add some vibration damping device or helical strakes to address the vortex shedding, otherwise if you increase the thickness to handle the vortex shedding loads then you will end up with a very thick stack.]
Section 4.4 does not clearly address what to do when equation 4-6 is not satisfied. The 2nd paragraph (below) could be interpreted as "when Eq 4-6 is not satisfied, design per the AISC". Is this interpretation correct?
[Response: That is my interpretation as well, and this is what I have done in practice. Typically this condition occurs when we have a relative thick shell, and so my conclusion was that it behaves more as a "Beam" and we can ignore local buckling concerns of a thin wall shell.
"All other steel members shall comply with the requirements of the American Institute of Steel Construction (AISC) specification for the design, fabrication, and erection of structural steel for buildings"
After reviewing Troitsky, Cheng, Gaylord and the AISC, it is apparent that when eq 4-6 is not satisfied, you are within the limits of a compact section (D/t < 3300/Fy). The sections of the stack that do not satisfy eq. 4-6 could then have their allowable stresses calculated by using equations E2-1 & E2-2 of Chapter E of the AISC. Again, does this thought and design process, when eq 4-6 is not satisfied, coincide with the intended design of the ASME?
Can a stack containing thicknesses that do not comply with eq. 4-6 still be "Designed per the ASME STS-1"?
[Response: In my opinion, since the standard indicates that if eqn 4-6 is not met then AISC should be followed, that you would meet the intent of ASME STS-1. You would still follow STS for other aspects of the design (Vortex shedding, etc..). ]
Thank you for your time Mr. X.
Any clarification or direction you could provide would be appreciated.
Best Regards,
