35% Hydrogen Peroxide Solution
I have forgotten this information.
I have a 150 Gallon Storage Tank that I'm going to disinfect with a 35% Hydrogen Peroxide Solution.
I need to know,
How many gallons of 35% Hydrogen Peroxide Solution do I use to disinfect the 150 gallons of water?
It's been a while since I've done this. Usually using ozone. I have some biofilm build-up so I'm going to use the Peroxide and let it sit overnight, then flush.
RE: 35% Hydrogen Peroxide Solution
Hydrogen peroxide
"Hydrogen peroxide is frequently used as a biocide in microelectronic-grade purified-water systems because it produces no by-products; it rapidly degrades to water and oxygen. A 10% by volume solution in purified water appears effective in killing planktonic bacteria, but more studies are needed on the effectiveness against attached biofilm" (Mittelman 1986).
http://www.edstrom.com/resources.cfm?doc_id=149
Looks like you will need 43 gallons of 35% peroxide to get a 10% solution.
Thank for the info. I have decided to go with Minncare cold sterilant at a 2% solution. Appears I will achieve the same result in a shorter period of time.
