Degrees of Freedom in Assembly Constraints
in NX3 during mating process, I could see the degrees of freedom and also after mating.
Now in NX7 it's possible to do this ?
Thank you..
Thank you..
RE: Degrees of Freedom in Assembly Constraints
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I read the what's new.
I'm afraid it was removed in NX5 with the new constraints method and add again only on NX7.5.
Regards..
John R. Baker, P.E.
Industry Sector
Cypress, CA
support told us that Assembly Constraints are the new mating paradigm.
Support told us to convert to Assembly Constraints and stop to use Mating Conditions.
Standard NX template have Assembly Constraints as default.
I think this switch is a little obligatory.
I suppose that you have credit point on each request.
Degrees of Freedom in Assembly Constraints have accumulated enough credit point from yours customer, because Degrees of Freedom is very important when add mates or understand which miss on a component.
Thank you...
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
