m-file in Simulink
m-file in Simulink
I would like to include m-file into Simulink workspace. Should I use 'Level-2 M-file S-Function' block, if yes, how it must be used if I want to include two variables, one is a number and second is a text.
I could simply use m-file in Matlab command window and calculate what I need, but as I would like to include m-file into Simulink model.
RE: m-file in Simulink
If you don't have the toolbox you can use an S-function. Although, you would have to convert your M-code to C-code...
Fe
Another way of doing that is to create a user function block, which would appear to limit you to one input and one output, but I see no reason why you couldn't MUX multiple inputs into a vector. I'll try that when I am next on a suitable box.
Cheers
Greg Locock
OP,
The"user function block" is the same as an "embedded function block". Which can handle any amount of inputs and outputs all in m-code.
Actually this is much simpler than an S-fcuntion for bergineers.
But, S-functions are far more powerful. (embedded only allows some external functions to be utilized) (whereas an m-file s-function can solve any n-order runge kutta DE as well as basic computations. ect.
Fe
it consists of two inputs, one is integer and second is char. The output is also char.
Cheers
Greg Locock
