Valves for FLNG / FPSO
I am working on FLNG project, i will be very thankful if anybody who has knowledge on FLNG / FPSO projects at EPC or at Valve manufacturer, tell me if any special valves are available in market for space saving.
Conventional Double Block & Bleed arrangement takes lot of space. Is their any valves available for positive isolation to replace this arrangement. Application will be CRYOGENIC (-196 deg.cel.)
Thanks in advance.
Thanks in advance.
RE: Valves for FLNG / FPSO
You might also try doing a search for previous threads on this subject by clicking on the grey search button above.
Finally a bit more information is always welcome. When you say "save space," how much space are you trying to save? What size opening do you need the valve to fit?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
I asked very generalised manner, Its not case specific.
I am thinking of some special valve which can replace 2 GTV, Spool Piece, Drain valve.
If you are looking to replace the traditional DBB piping arrangement, I'd look at the double-ball valve.
you may consider triple offset butterfly valves in a DDB arrangement ( ie two discs in one casting ) Zwick Valves of Germany have a lot of shipbuilding and cryogenic supply experience.
for more information about the Valve type mentioned by jeffvalve and a wider choice of Manufacturers, maybe you'll want to take a look at thread408-126483: Discussion on triple offset valve and thread408-135872: The top three sellers for butterfly valve? within this Forum.
Hope this helps, 'NGL
Zwick are good, so are Vanessa, Orton, Velan....(just the ones that come to mind instantly) take your pick.
Ciao,
Hobbs Valve is also capable of DBB and cryo valves independantly.
Craig Gingell
Hobbs Valve Ltd
Manufacturer of Triple offset butterfly valves in the UK
www.hobbsvalve.co.uk
I guess you should check them.
So, my advice is to reduce the dimensions of the complete system instead of only the valve; this is if the situation allows you, of course...
